Help with Ambient light seat ibiza 2016 1.2 TSI REF
Damhoes
I have the same BCM but my VCDS says Byte 17 is not in use.
can 1 enable this?
demonikx
44
you don't really need to code this byte because menu not work.
if you do the installation of foot well as i did it
you only need to code those adaptation
-Leuchte10SHUTTER LRB45-Dimming_AB_10 — 100
-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10 — 03
-Leuchte10SHUTTER LRB45-Light_Function_A_10 — Footwell
-Leuchte10SHUTTER LRB45-Type_Of_Load_10 — LED Kleinleistung ohne Open Load Diagnose
-Leuchte10SHUTTER LRB45-Dimming_СВ_10 — 5
-Leuchte10SHUTTER LRB45-Light_Function_С_10 — Terminal 58xs dimmer
and all will work good for you
pq-26 not supprted menu for footwell
Damhoes
Thank you so much, i am going to buy a led kit and let you know.
For now, thank you!
Reactions: demonikx
Damhoes
You are welcome 🙏 if you will have any questions feel to ask
Just installed it in the car and have done the configs and it work great!
I have set the following for Seat Ibiza 6P SC:
-Leuchte10SHUTTER LRB45-Light_Function_A_10 — Footwell lamp
-Leuchte10SHUTTER LRB45-Type_Of_Load_10 — 2*5W
-Leuchte10SHUTTER LRB45-Dimming_СD_10 — 30
Only thing i'm not sure of is the type of load settings, i have just 2 normal halogen 5W bulbs in it.
What is the best settings for halogen lights?
demonikx
44
I had leds and it was coded for leds
C channel it’s channel for power of light when you driving i think 30 will be very brightly. Just try and config it for you
Damhoes
Ik works great, the light for driving are now on 20 and that’s for me the sweat spot.
Reactions: demonikx
