I have scanned a friends car he has a 1996 passat 1.9 td
suddenly he will get a total loss of power followed by a cloud of smoke behind him then the power is fine again.
the code vag-com showed is
Control Module Part Number: 028 906 021 DD
Component and/or Version: 1.9l R4 EDC SG D84
Software Coding: 00000
Work Shop Code: WSC 00000
1 Fault Found:
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
i did a few searches and came up with....
00575 - Intake Manifold Pressure: Control Limit Not Reached
[edit]
Possible Symptoms
* Sudden complete loss of Power
* Reduced Power
[edit]
Possible Causes
* Hoses incorrect connected, disconnected, blocked or leaking
* Pressure unit for turbo charger defective
* Solenoid Valve for Boost Pressure Control (N75) defective
[edit]
Possible Solutions
* Check hoses
* Check pressure unit for turbo charger
* Check Solenoid Valve for Boost Pressure Control (N75)
* Check Basic Setting > MVB 011
[edit]
00575 - Intake Manifold Pressure: Control Limit Exceeded
[edit]
Possible Symptoms
* Reduced Power
* Charge Pressure too High
[edit]
Possible Causes
* Turbo Charger defective
[edit]
Possible Solutions
can anyone shed any light on this thanks
1 Fault Found:
[edit]
Possible Symptoms
* Reduced Power
[edit]
Possible Causes
[edit]
Possible Solutions
* Check hoses
[edit]
[edit]
Possible Symptoms
* Reduced Power
[edit]
Possible Causes
[edit]
Possible Solutions
