dirtydenz
I have 04 reg leon 130 tdi and its developed a strange noise when you brake or set off forward or in reverse. The noise is like a cracking sound and sounds quite substantial. It comes from the passenger foot well sort of area. Its got the dealership baffled. They've fitted a new wheel bearing and ball joint. The subframe and all the suspension has been off and been greased up on all the bushes and mountings. They've also fitted a new door hinge because they thought that might be the problem. The car has been sent to the body shop too so it could be checked for the body flexing in anyway. Any work that has been done has not affected the noise its still there.
Its hard to descride the noise other than a cracking. Its not a knock or a bang.
It's been suggested that maybe a spot weld on the chassis or something like that.
Has anyone got any suggestions or experienced anything similar.
The dealership say they have exhausted their means so it needs to go to the technical department in Milton Keens. But they are dragging their feet and its really beggining to do my head in.
