help! steering wheel shaking left and right??
got_boost?
my steering wheel every so often shakes slightly left to right. it worsens if speed up or slows if i slow down.
had a visual check underneith today but nothing jumping out as wrong. everything seems tight.
checked p/steering fluid its above min.
all bushes look correct
joints look in order
camber at bottom of suspension strut look tight.
no play in bearings
im out of ideas?
anybody else had this trouble or anybody hazard a guess to what it could be???
before i bite my lip and grab my wallet and head to seat dealers:cry:
LeeCourt
What wheels you got on? are they the correct fit? you might need spigot rings for the center bore.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
wheel balance, loose wheel bolts, loose something on suspension strut.... the list goes on.. a good spanner check needed me thinks
got_boost?
Shaking how bad?
Tyres both ok? No nails or anything?
Equal pressure at the front tyres? Missing a balancing weight?
richN
shakes enough to make your hand move with it when gripping it tightly to hold it in a straight line. no weights missin that i know off. could do with checkin the pressures though.
leecourt
there compomotives 17" the fit perfect to the lip of the hub
ibizacupra
i already checked it over once but its bugging me so much im gonna give it a good go over at the weekend again. so ill leave car off the road till then. then if still no joy ill have to get somebody else to look it over.
thanks for the replys guys
