Hi all
I am new here. Wondered if anyone could shed some light on a problem I am having.
I have a Seat Ibiza 1.2 Turbo 2015 plate - i love it! I purchased it last year after a crash made my humble Hyundai a write off.
But - It judders, randomly. I had it checked by the garage that i purchased it from but as it had 3 month manufacturers warranty left on it i have been in a constant battle with Seat Uk to fix the problem.
The garage i purchased from gave me a report stating a missfire in cylinder 4 & 2. Fault codes as follows:
P030000 Random multiple missfire
P0304000 Cylinder 4 missfire detected
P0302000 Cylinder 2 missfire detected
I took it to my local seat dealership. They said they couldn't find the fault and that it is a characteristic of the engine.
I took it for a second opinion at another Seat dealership and they told me it was a carbon build up issue due to short journeys by the previous owner - most likely. They cleaned the carbon and told me they had fixed it, but it still judders.
They had it back and completed the following, yet it still judders.
"We have carried out a number of tests and checks, including compression tests on the engine. All of these checks have shown no faults with the engine. With regard to the spark plugs we have not been able to fault them, but have changed them to ensure there are no issues with them we cannot detect. We have also changed the high-pressure pump, and swapped the coil pack. Again there are no faults with the engine, it is behaving as it should be when we test it. At this stage, we are unable to go any further, as everything is coming up as ok."
Is there any information on this fault you guys can give me? Any one else having this issue?
Many thanks
Many thanks
