matylad
278
Crewe, Cheshire
Im going to be sorting a few jobs out over the next few weeks one of which involves changing the power sterring pipe that runs over the top of the gearbox the other is replacing the gearbox oil.
I've priced up the pipe for the power steering...its £116 + VAT:headhurt: Do I need anything else with this? Im obviously going to need power steering fluid, will a litre be enough? Do i need any new seals when replacing the pipe? Is there anything i should look out for procedure wise i.e special bleeding method etc etc?
Will the Millers gearbox oil be ok?
http://www.millersoils.net/1_Millers_frame_AUTO_RETAIL.htm
Im also changing the engine oil so ordering from the same place makes sense. How many litres will i need? I have 4 in my head for some reason but i dnt know why :confused:
Cheers, Matt
