Help over heating 120c!!!!!
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hello all,
I just replaced my Oil pressure switch and then disconnected my battery for 20min on my 03 LCR which cleared the Yellow warning light off my dash, i just brought the LCR for a spin and then i noticed when i got back the temp gauge was reading near 120c, 117c in VAG 409.
Can anybody tell me what the problem could be, i notice my fans did not kick in.
All i did was disconnect the battery and replace the oil Pressure switch, nothing else.:confused:
Rob
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
are the fuses for the fans under the bonnet by the battery ok?
water pump ok?
think there has been a few threads about overheating, have a search and see what turns up
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
One of them looks a bit bend out of shape and one of the contacts looks burned, i will swap it with a new one and test. There are 3 fuses on top of my Battery, so i assume you mean those ones?
Also how do i get a picture into the message, i find it helps other people if they are reading posts.
Cheers Al
Rob
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Al,
I replaced the Green 30Amp fuse and the fans are kicking in now.
Weird the old fuse didn't blow, but did look like it was melted around the contacts.
Anyway thanks a million for your help.
Rob
jsparks
water damage to the fuses mate, its worth replacing all 3 fuses if thats the case. blocks the contact
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Will do, At 50c a fuse its defo worth it, i would say it was water damage alright, its kinda spitting rain here in Ireland today when i was under the bonnet.
