Had my car on the rollers yesteday and pulled a miserable 212bhp/272lbs/ft of torque on a k03s, where previously i pulled 227bhp/253lbs/ft torque on a k03.
Now something funny was happening between 4-5k, the car was smoking a lot, mixture of grey and blue smoke and didnt make the power.
Here are the logs, but they look fine to me, 183g/s, nice WG duty etc... until i done the ross tech A/F ratio calculator and see the below...
I've suspected its valve stem oil seals as compression is fine and i get blue smoke after overun e.g goin down a hill in gear then puttin my foot back on the accelerator, but could i check anything else? Shitted up lambdas? Vac leaks?
Any help would be good.
Thanks.
Code:
Group A: '002 Group B: '020 Group C: '118
RPM Load Inj. On Time Mass Flow Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Temperature Load Absolute Pres.
TIME TIME TIME
STAMP /min % ms g/s STAMP CF CF CF CF STAMP /min °C % mbar
0 1320 86.5 9.02 23.39 0.5 0 0 0 0 1 1320 20 100 1200
1.56 1320 85.7 9.02 22 2.15 0 0 0 0 2.7 1560 21 100 1250
3.2 1680 96.2 10.25 31.56 3.7 0 0 0 0 4.2 1920 21 100 1390
4.7 2000 108.3 11.07 43.72 5.21 0 0 0 0 5.7 2240 21 100 1700
6.2 2400 151.1 16.81 72.14 6.7 0 0 0 0 7.21 2680 23 83.9 2390
7.7 2800 191.7 22.14 107.92 8.26 0 0 0 0 8.86 3040 24 80.4 2540
9.4 3200 191.7 23.78 120.78 9.9 0 0 0 0 10.42 3400 26 76.9 2540
10.9 3520 191.7 23.78 142.06 11.39 3 0 0 3 11.89 3680 27 71.4 2540
12.4 3800 191.7 23.78 150.08 12.89 3 0 3 3 13.41 4000 30 61.6 2530
13.89 4080 180.5 21.32 133.81 14.41 3 0 3 2.3 14.91 4240 30 57.3 2190
15.5 4320 169.2 20.09 141.31 16.06 2.3 0 2.3 2.3 16.6 4560 32 57.3 2160
17.1 4680 170.7 20.5 152.86 17.59 2.3 0 2.3 2.3 18.1 4880 33 58.8 2130
18.6 5000 169.2 20.5 157.14 19.1 1.5 0 2.3 1.5 19.6 5200 35 60.8 2060
20.1 5280 166.9 20.09 169.25 20.61 3.8 0 1.5 1.5 21.1 5480 37 61.6 2030
21.61 5560 159.4 19.27 169.56 22.2 3.8 0 1.5 0.8 22.77 5760 39 63.5 1970
23.3 5880 155.6 19.27 175.19 23.8 3.8 0 0.8 0.8 24.3 6080 41 66.3 1910
24.82 6160 152.6 18.45 179.5 25.3 3 0 0.8 0.8 25.8 6320 43 69.4 1880
26.3 6440 147.4 17.63 181.39 26.8 3 0 0.8 0 27.3 6640 45 71.8 1860
27.8 6720 144.4 17.22 182.97 28.31 2.3 0 0 3 28.82 6880 47 75.3 1830
29.41 6960 137.6 16.4 183.75 29.97 2.3 0 5.3 3 30.52 7080 48 0 1690
31 6200 7.5 1.23 7 31.51 0 0 0 0 32 4480 39 0 1090
32.5 3840 8.3 0 6.42 32.99 3.8 0 3.8 3.8 33.49 4240 37 0 1310
33.98 3480 8.3 1.23 4.81 34.49 0 0 0 0 35 2240 35 0 1070
Code:
RPM Load % A/F ratio
1320 86.5 17.36
1320 85.7 16.33
1680 96.2 16.12
2000 108.3 17.32
2400 151.1 15.52
2800 191.7 15.03
3200 191.7 13.69
3520 191.7 14.64
3800 191.7 14.33
4080 180.5 13.29
4320 169.2 14.08
4680 170.7 13.78
5000 169.2 13.25
5280 166.9 13.80
5560 159.4 13.70
5880 155.6 13.38
6160 152.6 13.68
6440 147.4 13.85
6720 144.4 13.71
6960 137.6 13.98
Thanks.
