Help! oil coating on hose on LCR.
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
When doing my under the bonnet checks last weekend i found that there was a coating of oil around the nearside boost hose (the one that goes from the intercooler to the throttle body).
The car is revo'd stage one. Had a look around but there doesn;t seem to be oil on any other parts in the engine bay. Any suggestions or previous experiences before I take it down the garage for a closer inspection?
Mitchy
TTRS
Oct 12, 2004
2,310
Inside the hose is normal.
Outside hose, probably a drip from last top up/fill.
Apr 24, 2007
985
W. yorkshire
but if he has cold side relocation and split r of bov then it can splatter some of oil from inside outside through the valve
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
Its on the outside of the hose Dave and is more like a mist not a drip. Have cleaned off ond will check again later today but bit worried like.
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
I thought about that because it is only on this hose and nowhere else. Wont be happy if its the hose because its a forge one. Will tighten the clips and clean it up then try again, thanks people i'll keep you posted.
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
Oh no! think it may be more than just the pipe. I took the engine cover off for closer inspection and saw some greasy dirt build up round the edge of the head gasket. Cleaned up as best i could and have run the car for a few days. Checked again tonight and there is what looks like oil in one of the spots i had wiped clean on the side of the block. Also there looks like there has been something leaking from the injector nearest the near side of the car. I think i'm going to have to throw the old airbox back on and take it back to the dealers as it's in warranty until march :cry::cry:
Not holding out much hope as i've been waiting for nearly two weeks to see if they are going to sort out my near side brembo caliper which the lacquer is peeling off.[:@]
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
When you say round the edge of the head gasket, do you actually mean the rocker cover gasket, Craig? (Head gasket is below the level of the bottom of the inlet manifold).
phantombantam
NUFC forever!
Jan 23, 2006
627
Co Durham
Ok dave cheers for that i'll get on to them, do you think i need to fit the original DV before taking it in? Not going to bother changing the front boost hoses back as i cant see how they can blame them for any problems.
