Help needed with 17964 Charge Pressure Contr. Negative Deviation
poliq
four-by-four fan
Aug 4, 2010
559
Røros, NO
Hi! I came here to hopefully get some help with sorting a few things out. Does anyone know what could be causing the following?
I'm sorry for the wall of text, but I didn't want to leave out any important information.
The car in question is a 2002 SEAT Leon cupra 4 TDI, 150hp ARL enginge, (with a 190hp/310lb/ft remap) and just shy of 130000 miles on it
The main problem is that the car keeps going into limp mode all the time.
It looks like it doesn't really matter how i drive it, as the limp mode will kick in at some point anyway. This usually doesn't take very long.
Also, there is a major boost lag while not in limp mode as well. This varies between ~2500rpm up to as late as ~4000rpm.
It can be reduced a lot with quick gear changes at high rpm, but then again I don't want to keep pushing the engine in the state that it is..
00779 - Temperature sensor for external temperature (G17)
What does this one do? Is it just the for the outside temperature displayed in the instrument panel? And where is it physically located?
Personally I'm guessing that there must be a boost/vacuum leak somewhere, but I don't know it for sure. Is there any chance these fault codes are related?
Code:
Tuesday, 08 November, 2011,16:44:03:15589
Chassis Type: 1M - Seat Leon / Tol 00> 05
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R999999 Mileage: 207030km
Address 01: Engine Labels: 038-906-019-ARL.lbl
   SKU: 038906019 FK
   Component: 1,9 l R4 EDC 0000SG 1469
   Coding: 00003
   Shop #: WSC 06441
   VCID: 65CAFAC9D5F1
An error found:
            P1556 - 35-00 - -
Readiness: 0 0 X X X
Address 08: Air conditioning Labels: 1M0-820-043.lbl
   Item No: 1M0 820 043 D
   Component: 1M-Climatronic X0605
   Coding: 00043
   Shop #: WSC 06441
   VCID: 234EA4D19B45
An error found:
            30-00 - Interruption or short circuit to positive
End ------------------------------------------------- -------------------
A big thank you in advance!
sssstew
Editing your spelling
OK so negative deviation means its getting a lot less boost than it expects, so im going to hazard a guess at a boost leak somewhere, check all your boost pipes and joints and clips. Are you seeing some smoke out the back when it occurs also?
poliq
four-by-four fan
Aug 4, 2010
559
Røros, NO
Id say that there's an occasionally added puff of bl ack smoke. But I really only noticed it a couple of times. Most of the there is no extra smoke to see. Uses a lot of diesel tho.
poliq
four-by-four fan
Aug 4, 2010
559
Røros, NO
Yeah I thinkI have a joint or two to check, or even replace..
Yeah that's some snow caught up behind the bumper..
