Right need your help guys and girls I need to no how tho fit a set of wheels ie what spacers what hub adaptors I need the wheels are 20inch 8.5 j on the front et 52 and 20rears 10.5 j et37.5 on the rear I no the rears will need a dirty stretch but that's fine .
Standard ride height at the min but want coilovers other wise it will look crap . I'm just unsure of the et that's what confuses me what's the leon is it et35 . And does et mean how far it sits in or out the arch I no the j is the width thunking two sets of the fronts will fit as not sure if 10.5 will fit don't want to roll the arches tbh
The higher the offset [ET] the further in they will sit.
With a 20mm adaptor..............An 8.5 on the front you should get away with but you might have to take the helper spring off the coilover to get clearance [my 8.5x18 are ET33 and are bloody close to coilover but they dont rub.]
I think you will have lots of trouble with 10.5" on the rears......by the time you have put a hub adaptor on the already pretty low ET of 37.5 they will be sitting right out of the arch?
Ah ok I understand it a little more now so I'm thinking I need 2sets of fronts as rears will be a pain thanks for the help tho . There maserati wheels may take a while to find lol
