Help :/ need to replace ds rear door lock its still in the car i
Benny2k10
Hi i have a 03 leon cupra R my rear doorhasstoped unlocking so ivegot a new lock ive striped the inside the door and tryed everything to get the doir to unlock from the inside but it seems it is stck on dead lock :/ please can any1 advise me on howto go about this ?
sockpuppet
837
Get someone to repeatedly press the unlock button on the drivers door while you bash your hand against the handle of the locked door. Hopefully it will unlock after enough tries.
There is a round disc you need to punch/drill out to get the window out, to get to the door lock. Put something between that and your door skin to avoid damaging the door
wisesmurf
102
Dublin, Ireland
I've done this job recently. If you have the card off the door I found pressing the unlock button whilst pulling on the unlock cable that feeds to the grabhandle worked.
If that doesn't work, try as above. Press unlock and bang the pannel to just the left of the handle.
Benny2k10
Replaced lock by smashing old 1 out didnt damage the car :) checked wire with the oppisit door and all that was the same so seemed ok door was working fine from outside and inside so i thought great and started to put back together pluged the lock in put door panel on then went to open the door and its locked again and not opening its moving ect wen pressing lock unlock but not unlocking from outside or in any ideas ? Im thinking maybe its the central locking control unit ? Im more cause my mot is out real soon and it needs to open for that :/ just wish i never pluged it in grrrr but all the wiring ext seemed to b fine
