Help for the noob
RobGT28
Hello,
Im a new owner of a leon cupra r which spends most its life sitting in my garage eating my money but thats beside the point lol
I have looked through the search function for the 2 questions i have but there seems to be quite a few mixed replies and different suggestions like 10mm spacer, 15mm spacer im not use to this im a Honda boy previously lol
My questions are:
Where can you buy a facial plate to change the old head-unit for a new one, because the old one is nasty, ebay doesn't seem to have the answer
Wheels, this seems a funny thing for leons because a starfish decided to give them odd ball specs
So 18'' et38 5x100 7.5 - Can i get away with 8'' without spacers? And what is the max et you can run on a leon also without spacers, i don't want the wheel sitting right in the arch but i dont want it protruding
As i said, i apologize in advance as i can imagine these get asked 45 times per week
RICKY3
1,002
AYRSHIRE
Ebay
spudboy6
721
114
Swindon
I run
8j front 9J rear et35 all round on 225/40/18"
No rubbing on any arches fills them well , front wheel is very close to the coilover but clears by MM's
Hope that helps
RobGT28
Will they fit ok?
18x8.5" Alloy Wheels (5x100 et35) ( dont want it to catch the brembo's )
spudboy6
721
114
Swindon
Will they fit ok?
My 8's only just miss the shock absorber so 8.5 will catch so would need a lower offset like a 30 but someone else will confirm that as I'm not sure
RobGT28
^ Thanks mate... this the only thing im struggling with is the wheel choice i want to make but ive never understood the whole et, width and all that :/
Bah humbug
spudboy6
721
114
Swindon
If you have a ET off 0 , where the face of the wheel meets the car hub is the middle of the wheel , when you go into the - so eg ET-7 (old school mini ) the centre of the wheel is closer to the inside of the wheel so sticks out more
Then vw ET30 is closer means the bolting face is closer to the spokes of the wheel so the wheel sticks in more but
Width is obviously wheel width but when you go say 8" to 9" its only half an inch wider each side of the wheel
If you know the spec of your current wheels
This will help you work out what will fit your car
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
