Right Its time to get this sorted:
Ive scanned Normal Engine Mode and nothing came up..So then scanned the Abs section and this came up
VAG-COM Version: Release 311.2-N
Control Module Part Number: 1J0 907 379 AF
Component and/or Version: ASR 20 IE CAN 0001
Software Coding: 13404
Work Shop Code: WSC 00000
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
I clear it and soon as i start moving(driving) it comes back and stays there till i turn the car off then same again...
Cars Brakes and feels fine? Any Ideas were to check
Also my Tcs is alway off when the lights are on but once i clear it then works then the light appears a few minutes later
THanks
1 Fault Found:
THanks
