Help! Fitted abs sensor and still have light
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Right Its time to get this sorted:
Ive scanned Normal Engine Mode and nothing came up..So then scanned the Abs section and this came up
VAG-COM Version: Release 311.2-N
Control Module Part Number: 1J0 907 379 AF
Component and/or Version: ASR 20 IE CAN 0001
Software Coding: 13404
Work Shop Code: WSC 00000
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
I clear it and soon as i start moving(driving) it comes back and stays there till i turn the car off then same again...
Cars Brakes and feels fine? Any Ideas were to check
Also my Tcs is alway off when the lights are on but once i clear it then works then the light appears a few minutes later
THanks
darren_mcvicar
abs ring is probley cracked either that or you need an abs sensor mate send a fault up for tcs also
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
And that relates to a pump fault because...?
Check the wiring to it as mine flagged a intermittent fault which turn out to be a worn wire failing that looks like the pump itself.
cupra collins
216
check your wheel has not rubbed through the asb sensor cable mate thats what happened to mine a couple of through crimps and cable ties soon sorted that out tho
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Thanks you lot :d
When you said Number 8 fuse do you mean the fuse box under the steering wheel..
I only started gettin this code when my spanner touched and Block and Alternator and flew the fuse on top of the battery...
It been Like this ever since.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Id be checking the wiring to the pump not the sensors as your getting a pump fault rather than a sensor fault.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeha benny im going to...
I only started getting this light when my Spanner touched the alternator wen i was doing up the oil braided line...which shorted the fuse on top of the battery...
And it woundnt hold charge...
So i might have blown up the abs..or damaged it...What other abs pumps fit the ibiza?
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
arrr Seem the Yanks might have sussed it..
I might have Burnt out the Wiring from the Battery to abs Module...Wen i shorted it all out?
gonna check 2morro
Edit:
What ABS control module itself? Not the pump
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Right i keep getting this tcs and abs ligh and it wont go away even wen i clear it//
its comes right back on...
Ive check my installation of the sensort and does it have to be touching the abs rotor?And ive checked all the fueses
As it isnt at the moment..All the wiring under arch seems fine not damaged in anyway.Ive replaced the drivers side abs sensor and its still there..Have i replaced the correct side?
This is the code im getting:
00285 - ABS Wheel Speed Sensor Front Right (G45): Signal Outside Specifications
00285 - ABS Wheel Speed Sensor Front Right (G45): Electrical Fault in Circuit
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
ABS Wheel Speed Sensor Front Right (G45) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Check ABS Wheel Speed Sensor Front Right (G45)
00285 - ABS Wheel Speed Sensor Front Right (G45): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Front Right (G45) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Front Right (G45)
Possible Solutions
Check ABS Wheel Speed Sensor Front Right (G45) Installation
Retrieved from "http://wiki.ross-tech.com/index.php/00285"
