Help failed MOT
Aug 30, 2004
662
Stockport
My beloved LCR failed the MOT test for the second time today on emissions.:cry:
APR stage 2 with Blue Flame turbo back with 100-cell cat.
Ever since I had the BF system fitted its thrown up regular fault code for the 2nd Lambda.
This fault has been discussed many times on here and the consensus of opinion seems to be that the Lambda needs to be spaced out a little by fitting a suitable spacer between the sensor and the boss or a spark plug arrestor?
Would fitting such a spacer bring down the CO2 emissions?
I often get a strong smell of fuel on idle, could the Lambda be responsible for over-fuelling? this would tie -up with with the above
The most important question is where can I acquire such a spacer urgently?
Any help on this would be much appreciated.
Keith
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
when the car went for mot, did you pu the catayst as yours is decated. I think some revo remap, its possible to restore the factory boost stock so it wont let 2much emission of.
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
APR isnt switchable so not possible
makes me think this, im thinking of exhuasts at the mo and considering BF with 100 cell cat-they told me it will easily pass MOTs
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
when you say it's failling.... on what is it failling?
can you type in the reading, and the fail level?
Aug 30, 2004
662
Stockport
Hi Mark.
These are the readings
Fast idle test Fail level =< 0.30%
CO 0.63%
HC 40ppm
Second fast idle test
CO 0.64%
HC 37ppm
Natural idle test Fail level =< 0.50%
CO 0.66%
Keith
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
spacer won't help - the 2nd probe is just there to make sure the cat is doing something (once the car is warm)
what's the lambda reading?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
4bar fpr in ya car?
fuel trims high ?
CO level is too high, block 30/31
leaks in ya exhaust somewhere?
Empi5
Your scaring me.......
Feb 24, 2005
2,807
Staffordshire
Keith you had your Blueflame fitted the same time as mine, and my down pipe split almost in two, worth checking.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
if this is the case keith is will be the centre weld on the bend... and if it has gone dont worry, you will get their new design DP which is much better! ;) :yes:
tho i doubt this problem would cause you to fail emissions?! :shrug:
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
I had a split in the exhaust manifold on my M3. It draws air in through the split, so the exhaust gases passing the lambda are 'diluted' compared to what is actually leaving the combustion chamber. The lambda reads this as running lean, and so dumps more fuel in to compensate. So now, the mixture is too rich, not all the fuel is burnt and it gets dumped straight down the tube. Sadly when an MOT man is at the other end, its leads to glum faces all round.
