help 12 faults found :(
shantybeater
loving the whoosh
Sep 28, 2007
645
Bournemouth & Brighton
12 Faults Found:
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating Circuit: B1 S1: Short to Ground
P1115 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
Once the results had been cleared all the lights on the dash turned off, the boost returned, then i took her for a drive, this fault stayed on....
P1421 - 35-00 - -
Then after a bit of boosting onto a duel carriageway all the faults returned...
Anyone have any ideas what it could be? I assume one of the problems is definately the lambda?
Feb 1, 2007
1,293
gloucester
check the ecu isnt wet as well , its just under the panel below the wipers , it wouldnt have that many fault codes , unless there was a short circuit , or wet ecu , my old cupra r ecu got wet and threw up loads of fault codes , wate gets to them very easy , i dunno why seat didnt make a cover to go over them
shantybeater
loving the whoosh
Sep 28, 2007
645
i know for a fact the lambda sensor fuse is blown, i tried replacing it but it instantly blew again after? I'll check the Ecu this morning, as it heavily rained the day these faults arrose, not having much luck with her at all at the mo :(
shantybeater
loving the whoosh
Sep 28, 2007
645
Ok took the car to paul at apd this morning, the mans a complete tool, he sourced the problem straight away, one of my sensors had dropped down the back of the engine and was shorting, a new rubber bung & no more fault codes....brilliant
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
i always thought that saying was offensive???!!! glad its sorted mate.
PAUL@APD
I Am Not A Tool Thats Offensive, I May Look Like A Tool But I'm Def Not
