12 Faults Found:
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating Circuit: B1 S1: Short to Ground
P1115 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
Once the results had been cleared all the lights on the dash turned off, the boost returned, then i took her for a drive, this fault stayed on....
P1421 - 35-00 - -
Then after a bit of boosting onto a duel carriageway all the faults returned...
Anyone have any ideas what it could be? I assume one of the problems is definately the lambda?
P1421 - 35-00 - -
P1425 - 35-00 - -
P1547 - 35-00 - -
P1435 - 35-00 - -
P1289 - 35-00 - -
P1117 - 35-00 - -
P1114 - 35-00 - -
P0102 - 35-00 - -
P1115 - 35-00 - -
P0134 - 35-00 - -
P0140 - 35-00 - -
P1421 - 35-00 - -
