jayblue
Hi all my heater is blowing out hot air all the time, regardless of what i set the climate control to, the flow rate or whether air con is on or off. Setting the cabin temp to high or low makes no difference to the air temp. The air con does "click" on when i press the button and my coolant temp is normal. The coolant also gets up to temp nice and quick. I have already replaced the coolant temp sensor with a revised "green" one this summer.
Could this be thermostat or outside temp sensor failure? I noticed that my outside temp on the dash was a little high this morning at 13 degrees but otherwise it has been fine. Suggestions appreciated, my car is an LCR 225 53 plate.
