Heater Control stuck on hot.
Tammis
The other day I switched on the heater control as it was a little chilly, but I now have continually scorching hot air coming through the vents. I've tried putting the control to hot and back to cold a few times but nothing changes. This happened before but used to sort itself after engine was switched off or the heater vent selection was changed.
Any ideas?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
at a guess it's a mk3 ibiza ??
if it is they have a nasty habit of the heater flap control motor jamming and packing up
with your ignition off reset it sounds like it but has eventually gone POP :( sorry
NS lower dash on the side of the heater box with a red arm on it i think it was may be worth a manual manipulation ????
Tammis
It's a 97 mk2 Gti/cuprasport 8v.
Thanks for the info, I might have a look at the heater box when I get a moment. It's bound to be similar?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ill have a dig round mine then - think its cable
take the surround off round the controls (clipped on) be gentle
4 screws from memory hold heater control panel in
wiggle it out to enable viewing of the rear and check if the cable moves when you turn the heater knob :p
if all ok follow cable back from there
probably the wheel broken or unclipped
Tammis
Managed a look the other night, and its just the arm connected to the control wire doesn't fully return to position after being opened to hot. Followed the wire and gave it a prod. Everything seems fine and cool for the moment, but will have a proper look during the holidays.
Next problem is figuring out why so much heat from engine escapes into car through steering column area, unless its normal? Just seems a bit excessive to me.
cheers again.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
cheers again.
theres a gaiter/sock around the bottom of the column thats right by the downpipe
they seem to just pop out but are a b@5t4rd to get back in
