Hi everyone I'm having some sort of electrical gremlins with my Leon. It's booked in for work soon so im hoping this might solve the issue but until then i've been trying my best to either diagnose the issue myself or fix it with my limited skills and resources. Apologies this is a long thread!
so the main things first and foremost
Leon 3rd 1.2TSi 110 2014 un modified.
car regularly service. approaching 60k mostly does motorway miles through week 30 mile round trip to work.
video link of issue:
The problem appeared out of nowhere last wednesday morning i jumped in the car to go to work turned the ignition to on and blip! everything just went dead. Nothing. couldn't even lock the car. Opened the bonnet to see if anything obvious was amiss and no. So for all the good it did i tried again and got nothing except for the dash and middle display flickering a bit before dying. Called the AA out. patrol tested battery and said it was fine. He wiggled the terminals a bit and told me to start the car and it damn well started! So went to work. But since then the issue has appeared over 5 times and is a real headache. I seem to be able to get the car going. AA have been out to it again and tested battery again, tested alternator and still nothing obviously wrong. Patrol could not see any issues on grounding points he could see either.
report is as follows:
Patrol found the following fault code/s:System : Engine control - VMC / Motronic MED 17.5.25 UDS Status :U112300 - Data bus. Error Message : Signal reception. Static fault. Status :U042800 - Steering wheel angle sensor. Error Message : Signal improbable. Static fault. Status 044100 - Fuel evaporation system. Error Message : Flow rate faulty. Sporadic fault.No fault apparent, battery tested and passed, charging system ok. All ok. Engine Oil Level Ok. Coolant Level Ok.
for some reason wiggling or disconnecting the terminals and then giving it a minute or two seemed to work. I eventually had the idea to disconnect the cable/plug onto the negative that i read once was to do with the stop start system. As soon as i did that and tried to start the car it started straight away! and it worked absolutely fine all day yesterday, it got a good run out and i thought that might keep it sorted until i can get it to my preferred mechanic.
through desperation i also bought a carista just in case. the details from that fault are below:
CAN network gateway
Part #: 5Q0907530T
Component: GW MQB High
Software version: 1188
ASAM/ODX identifier: EV_GatewLear
Coding: 030100F42B085700EF000048080F00010001000000000000000000000000 (hex)
[No fault codes]
Central electronics
Part #: 5Q0937084AJ
Component: BCM MQBAB H
Software version: 0134
ASAM/ODX identifier: EV_BCMCONTI
Coding: 0B000A424201005B0B244000B10403081000000000000000000000000000 (hex)
Fault codes:
197644 Control circuit for fuel tank flap (electrical failure)
Steering wheel
Part #: 5Q0953507AC
Component: Lenks. Modul
Software version: 0070
ASAM/ODX identifier: EV_SMLSKLOMQB
Coding: 1400 (hex)
[No fault codes]
Airbags
Part #: 3Q0959655AC
Component: Airbag VW20
Software version: 0189
ASAM/ODX identifier: EV_AirbaVW20TS6VW48X
Coding: 98CCC000000000005C0000CC008800000065 (hex)
[No fault codes]
Instrument cluster
Part #: 5F0920972
Component: KOMBI
Software version: 4270
ASAM/ODX identifier: EV_DashBoardVDDMQBAB
Coding: 27A50A002980260001087A001000000000000000 (hex)
[No fault codes]
ABS
Part #: 5Q0907379K
Component: ESC
Software version: 0371
ASAM/ODX identifier: EV_Brake1UDSContiMK100ESP
Coding: 18EE8A9224202974007E060941C9241851249400608224F200210070C002 (hex)
Fault codes:
00297 Transmission Vehicle Speed Sensor (G38)
16390 Fuel Shutoff Valve A, Circuit Low
Power steering
Part #: 5Q0909144P
Component: EPS_MQB_ZFLS
Software version: 1043
ASAM/ODX identifier: EV_SteerAssisMQB
Coding: 0103 (hex)
[No fault codes]
Heater & air conditioning
Part #: 5F0907426H
Component: AC Manuell
Software version: 0705
ASAM/ODX identifier: EV_ACManueBHBVW37X
Coding: 04100004200100001000000000001000 (hex)
[No fault codes]
Front passenger's door
Part #: 5Q4959592B
Component: TSG BFS
Software version: 0014
ASAM/ODX identifier: EV_DCUPasseSideEWMAXCONT
Coding: 00100220C401040100001000 (hex)
[No fault codes]
Driver's door
Part #: 5Q4959593B
Component: TSG FS
ASAM/ODX identifier: EV_DCUDriveSideEWMAXCONT
Coding: 00100220C001040100001000 (hex)
Fault codes:
65548 Manufacturer-specific code
Headlight aiming
Part #: 5Q0907357
Component: LWR-ECU
Software version: 0080
ASAM/ODX identifier: EV_HeadlRegulVWLWRMQB
Coding: 048C000009000000 (hex)
[No fault codes]
Engine
Part #: 04E906027CJ
Component: 1.2l R4 TSI
Software version: 7798
ASAM/ODX identifier: EV_ECM12TFS01104E906027CJ
Coding: 01190012232419080000 (hex)
Fault codes:
17158 Manufacturer-specific code
07150 Manufacturer-specific code
Infotainment system
Part #: 5F0035858A
Component: MU-S-ND-ER
Software version: 0480
ASAM/ODX identifier: EV_MUStd6C1PASE
Coding: 04731001D70A000021111101000800002F0106060100010046 (hex)
Fault codes:
01555 Motors for central locking, SAVE
despite thinking my temporary fix might have worked it did not. and the car once again refused to start. I cannot get the car looked until the following tuesday. I live alone and have nobody else to currently fall back on for transport to and from work so i needed to get the car into some sort of working order. So i bit the bullet and went to get a replacement battery from halfords just to see if this might fix it. I also got it tested again while i was there. Both halfords and AA tests say the battery is FINE!
So i fitted the battery and registered it. Had some difficulty there as i didnt know the manufacturer code (i know their own brang agm battteries are made by yuasa but whats the code) Also couldnt read the damn serial number. But i did input the right amperhour and battery type.
cleared all errors. took the car for a ride with stop start disabled and its been fine. I did turn on stop start (using button in car) when i reached home to see if it would cut in but it did not and just threw the centre display stop/start error at me.
I've now reached the end of my skills and resources. If this new battery doesn't fix it i am a bit screwed until i can get it to a garage. If anyone knows of similar issues or can make sense of what i have put down so far that would be great. I've done as much searching as i can but couldnt find anything matching it.
CAN network gateway
Part #: 5Q0907530T
[No fault codes]
Central electronics
Part #: 5Q0937084AJ
Fault codes:
Steering wheel
Part #: 5Q0953507AC
Coding: 1400 (hex)
[No fault codes]
Airbags
Part #: 3Q0959655AC
[No fault codes]
Instrument cluster
Part #: 5F0920972
Component: KOMBI
[No fault codes]
ABS
Part #: 5Q0907379K
Component: ESC
Fault codes:
Power steering
Part #: 5Q0909144P
Coding: 0103 (hex)
[No fault codes]
Part #: 5F0907426H
[No fault codes]
Part #: 5Q4959592B
Component: TSG BFS
[No fault codes]
Driver's door
Part #: 5Q4959593B
Component: TSG FS
Fault codes:
Headlight aiming
Part #: 5Q0907357
Component: LWR-ECU
[No fault codes]
Engine
Part #: 04E906027CJ
Fault codes:
Infotainment system
Part #: 5F0035858A
Fault codes:
