have i bought the wrong turbo? help?
sods law
i have just bought a k04 part23 turbo for my cupra r (210bhp). picked it up from west london and realised that i actually need a part 22, (felt like a big muppet.) can i fit the part 23 or do i actually need a part 22??? is there anyone i can call to find out? appreciate any advise as i will need to fit in on sat. have been without the beast for 1 month .:shrug:
sods law
there are two the 22 and 23 i think the 225 bhp has the part 23 and 22 on the 210bhp.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
well if the 23 fits staright on with out any probz and run rights (with a few extra bhp). should be a plus then
sods law
they are the same!!!!
apperently the part 22 and 23 are the same. the only difference is there is a sensor in one and not the other. you can plug the gap to the sensor. i wish i knew this earlier, i paid top dollar for the turbo and i could ve got the part 23 cheaper. anyone know a decent garage to do the job. in east london/ essex.?
Stu_pot
Fire Starter
Mar 26, 2004
374
Near Blackpool
I believe the sensor is an EGT - Exhaust Gas Temperature sensor.
You will get a check engine light on the dash (if it's not connected) and a fault in VAG-COM but it won't affect the running one bit.
sods law
thanks guys. ill try the place out in witham on mon. i'm thinking about engine flushing and to run it now on fully senthetic instead of semi. plus i might do a stage 1 if the car still up to it. and the mrs lets me spend the dosh!!!!!!!!!!!!
wild willy
2,323
Wales
I have a 210 lcr and it defo has a k04-023 as standard. As Bill has said it is important to reconnect your egt sensor as this protects both the manifold and turbo. If the temperature exceeds 950 degs the ecu reduces the injector on time and so reducing enginne power until the temp falls back below 950 degs.
This temp is seldom reached under stock component driving conditions.:)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
ecu fuel dumps and drops boost to recover egt's......... nice feature to have and retain.. that said, I think re-reading this, his car does'nt have the sensor to begin with but the new turbo has got the hole for egt sensor.
