Hi folks, i'm in desparate nean of help.
My rear left pads has worn out on my LCR so i have bought a new set today to replace.
I have changed the pads on my previous 5 car with no problem.
I have undone the fixing bolts etc but no way can i open up the piston.
I have undone the top of the fluid reservoir etc, removed the handbrake cable to avoid any tension but no way can i open the piston to install the new pads.
I have even reatttahed the cable and seen the piston moving under the handbrake so doesn't look seized.
I have now even removed the brake line, bleed niple etc to rule out there being any presure but still no joy.
Normally once i have found a bit of play betweeen the pad and piston i can open the piston with a driver etc but no way will this budge.
Any help would be greatly appreciated.
Scott
Scott
