Has anyone bike carb'd their ibiza?
crossedmike
made it all myself, but a break down of the cost would be to convert the ABF
Carbs: 50
180 Jets: 12
Throttle accessories: 5
Inlet flange: 40
Inlet gasket: 8
Stainless steel for runners: 15
Welding: 45
Silicone hose and clips: 15
KR ignition controller: 25
KR distributor: 25
Thats pretty much it... that should see around 170/180 horse and more if tuned
You can make most of that back by selling the inlet off the ABF... simples
also if not tuned well... youll see in the region of 20mpg ;)
so tecnically a 20 - 30 bhp increase for such a low amount
crossedmike
Im actually tempted to stick a set of bike carbs on my little 1.4 for/as abit of a project. And I know it can be done.
i wonder wjhat increase you would get and what sort or sound :) if mine lives i would be tempted lol but would have no idea haha
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
If you got bike carbs of one of the smaller inline 4's like an r6 or gsxr600 then i reckon it might be fairly good.
crossedmike
I am really really tempted to do it, even if I dont get much of a power increase, I want it more for the sound. [B)]
A member on here, Novataken (Spelling?) did it to his 1.4.
u go first tell me how easy it is and if it blows up haha :)
HoopDub
157
havent seen any mention of an FPR here, bike carbs run at 3-5psi where as modern fuel injection pumps are many times more, you will need an FPR to knock down the pressure for the carbs to work properly, no great expense though.
to run carbs on a 1.4 you will need a distributor from a mk2 golf 1.3 and, and the ignition wiring from a 1.6 driver, amplifier etc fuel pressure regulator, custom inlet manifold, bike carbs and a fair bit of handy work
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
to run carbs on a 1.4 you will need a distributor from a mk2 golf 1.3 and, and the ignition wiring, amplifier etc fuel pressure regulator, custom inlet manifold, bike carbs and a fair bit of handy work
Thanks for that list, gives me a starting point to start looking and pricing stuff. I wasnt sure what I would exactly need.
I can do the custom inlet manifold as I work in an engineering place. And I doing mind doing abit of handy work. :funk:
crossedmike
this is why im envious i have 2 left hands and a mecanical mind of a goose lol good look if do it and get a video of the sound : )
HoopDub
157
theres plenty of room behind the 1.4/1.6 engine to get the carbs in, an ITG sausage filter is also advisable or similar.
CraigW
Craig.
Apr 12, 2007
4,607
I have plenty of people I can ask at work aswell for advice on making bits etc. Ive just spent 4 years doing my apprenticeship and now I'm qualified so I am rather mechanical minded.
Thats what gave me the idea of it, the amount of room behind the 1.4 engine. I was thinking of one of those ITG filters aswell. What sort of bike carbs would you recommend using??
HoopDub
157
hmmm, the best you can afford, zx6 ones are ok, 36mm throttles on them nice mach for the small engine, or anything 36mm and upto 40mm. theres probably a fair bit ive forgotten about this conversion, been a while since i did it. i will try dig out my old info
CraigW
Craig.
Apr 12, 2007
4,607
Thanks mate, you have been a big help. Needed to find something to keep the Ibiza as a project and I think I have just found it! :funk:
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Rather than running all that heavy mk2 golf stuff you could probably run megajolt instead. Or take it one step further get rid of the carbs and run bike throttle bodies and megasquirt.
HoopDub
157
many different ways :D the way i said was very low cost so thats the only reason i went down that road. also had a camshaft from a mk3 polo GT.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
EFI pumps run at 3.0 bar normally - approx 43 psi
