Has anyone bike carb'd their ibiza?
ibiza_95
1.8T MK2 Conversion
as title... has anyone actually ever bike carb'd their mk2 ibiza? Im thinking along the lines of the 2l / 1.8 versions...
im doing the same thing to a mk1 golf running an ABF engine, but its the same engine as some of the GTi's so figured someone might have done it on theirs?
Nice and easy to do in all honesty but cant remember anyone on here ever doing it
:D
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Why would you wanna do it? Bike Carbs suck for driveability and don't usually gain you much in outright power. Better off going throttle bodies and ecu such as megasquirt.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
considered it but stuck the standard manifolds on to make sure i'd bolted it together properly first and to be honest couldn't be arsed after that
ibiza_95
1.8T MK2 Conversion
heres a pic of my handy work :)
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
looks sweet mate!
what was needed? how much altogether/power figures (estimated of course lol)
bet it sounds SCHWEEETTT!!
ibiza_95
1.8T MK2 Conversion
made it all myself, but a break down of the cost would be to convert the ABF
Carbs: 50
180 Jets: 12
Throttle accessories: 5
Inlet flange: 40
Inlet gasket: 8
Stainless steel for runners: 15
Welding: 45
Silicone hose and clips: 15
KR ignition controller: 25
KR distributor: 25
Thats pretty much it... that should see around 170/180 horse and more if tuned
You can make most of that back by selling the inlet off the ABF... simples
also if not tuned well... youll see in the region of 20mpg ;)
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
thanks alot for that mate! you might have to make a build thread, as i will still be a n00b (might be others too)
that's quite cheap to be fair! :)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
KR distributor: 25
interested how you use these in the setup, was originally gonna run an omex ecu off the original sensors and coilpack ignition when i looked at it.
need more piccies to dribble over :p:p:)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
hurry up then !!!! :):)
never jetted a bike carb only reed valve's and pipes in my day sadly so if you get stuck in give us some pics
