Hello everyone.
I have a mk3 Ibiza 20vt. About six months ago a problem started to occur at my car. When the car is cold it takes about 10 seconds to get it running. If you turn it off and then start it again it turn on in half a second. Does anyone come up with this issue? Any help will be much appreciated.
I have changed the coolant temp sensor. Fuel regulator valve, spark plugs, pump relays.fuel filter.
Vag com doesnt show any fault codes.
About the time it started the problem i had replaced the crank sensor with an oem one. Is there a possibility that it could be faulty?
Thanks a lot in advance.
