Had H&R Kit fitted now getting knocking?
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
I had a H&R Cup Kit fitted on Friday and now when I'm turning corners slowly e.g. pulling out of a road or driving around a car park I'm getting a knocking noise from the rear left and front left wheels.
When it happens its not a constant knock but just a one off knock.
What could it be?
gavthelad
Bring on the Boooooost
Nov 19, 2005
1,394
Redditch (Midlands)
strange that both front and rear are knocking at the same time? it might seem a bit random but have you checked how tight your wheel nuts are?
Pabs
5,936
Basingstoke
You made sure all the bolts are done up tight?
My FK bolt came 1/4 of a turn loose - and was enough for the damper to move very very slightly - and was a rear D/S.
Once it was tightened, it went away :)
As for front - you checked its not too low, and hence fowling on the ARB?
truCido
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
Suppose I should check the wheel nuts. wouldnt of thought they would of left one loose :s I hope not anyway!!
uhhh not a clue Pabs!! You mean one on top of the strut came loose? The front I wouldnt have a clue to be honest however the kit was made for my car so it shouldnt be? and theres loads of people with it.
Pabs
5,936
Basingstoke
I thought the H&R kit were coilovers, hence adjustable? Now I've realised they are not :(
On the rear, at the bottom of the damper, there is a bolt that goes through the damper, with a nut the other side. Mine was very, ever-so-slightly loose. Caused an annoying knocking. It was possible to very slightly twist the damper when the car was in the air.
1/4 of a turn of the spanner - all sorted.
truCido
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
No this is a cup kit its fixed :)
ahhh ok, ummm will have to get a garage to check that out I guess, I'm crap with suspension :p unless anyone in the Reading area would like a look ;) ;)
roderrs
150
i had this really bad turned out the coil on the bootom of my fk had come loose:( i still get a slight knocking now tho
