Hi again!
I went and bought a VW RNS510 from the bay. Advertised as,
Version B
SW Version: 2760
Will fit cars with old CAN Gateways and will not cause battery drain.
Video in motion activated."
Just spent the afternoon and evening installing it. Big up to DanGB for writing the
guide in the first place. It actually is that easy!
The hardest part was removing the original radio in the first place. Took over 40 mins of a struggle, despite the fact I did 2 dry runs last week. (first took nearly an hour
, the second 5 mins!
5 nervous minutes with the dremel sorted the plastic bit at the bottom, I also cut out the bit at the back just to give me more room for the antenna connectors, although I'm not sure I needed it, as I was able to push the unit all the way back in as soon as the lower cut-out for SD card slot was made.
Powered it all up, and thankfully it worked. After about 5 mins it found it's location. I was going to put the gps antenna on the dash-under the windscreen- in front of the climate control sensor, where it showed a 5 sat reception. Put it under the dash on top of the air vent duct and it showed a 6 sat reception! 3 small bits of insulation tape secured it in place on the duct- out of sight! Put the aircon unit back in place (it's not necessary to remove it, but is does give more room to work with) and connected up the unit, and went for a spin.
Steering wheel functions all work, CD sound seems improved. Nav unit works fine. I ordered the fakra 1 into 2 antenna adapter from ebay but that hasn't arrived yet, so for now I have no radio, haven't tried the DVD yet either. Will go for a spin tomorrow and pick up a couple of SD cards to load my music. Still waiting on the local dealer to get the fascia plate. Tomorrow will also hopefully confirm the battery drain claim!
Thanks again Dan!
Roy
