Thought I'd bring this one back to the top as my resistors arrived in the post today
I started getting the Incorrect Air Flow at SAI ages ago,  think it was due to the N112 melting after it slipped down the back of the engine!
anyway,  removed the SAI and used a blanking plate where the valve was,  was still getting the incorrect airflow code so I ordered the resistors
in the meantime I disconnected the N112,    now the interesting thing was that since disconnecting the plug to the N112 I now just get one code.   The code is saying that its an open circuit to the N112,  which there obviously is because the N112 is in my tool box and the plug isnt attached to anything
No code at all for incorrect airflow!  before I was getting the airflow code every 2 days really
really hoping that tomorrow when I use the resistors I'll no longer get any codes or EML coming up
now the question is,   the line that did go to the N112,  circled in blue below.   Shall I now remove this bit of tubing for now and block the end where the join is so there is no more excess hose in place doing nothing.   Obviously a yes I guess!
The other part circled is the plug I'm about to put the resistor into
will report back on how things go after the resistors are fitted
