Guide - Removing SAI, N249 & n112 valve
james_seatcupra
I was the same turned out it was the n75
Roffel
Dutch Newbie
Jan 6, 2011
113
Netherlands
www.teamibiza.net
Did it like this:
Roffel
Dutch Newbie
Jan 6, 2011
113
Netherlands
www.teamibiza.net
Aid there a guide to taking out the evap system on bbu ibiza
You have to remove a cooling fluid line which is coming out of the engine.
Youll probably loose your fluid.
Then install the blanking plate.
Remove everything of the lines on top of the engine and the SAI pump which is located under your intake manifold.
Pictures 2 post before are from a BBU.
Adjay
393
Donegal,ireland
The blanking plate is for the egr, I already have the sai out and egr and also the n249 and n112 bit my evap lines are still there along with the evap canister and the pipes going into the wing, just looking for a guide on blugging up the system.
Pew.
1,451
142
Scotland
I have a brand new set of the plastic pipes that run from the airbox to the pump which gets removed if anyone wants them for the price of postage.
I removed mine a long time a go and still have the pump etc
