Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Hi all, I havent used my GTi since the bad snow started, now its not starting
there is no spark to the spark plugs.
Im hoping that its just the coil, but if it isn't is there any other common problems it could be?
Remove all spark plugs and check teeth to see if they have petrol on, or are bent. Also you might need a new rotor arm on your dissy cap if nothing is sparking, so check that as well.
Easy job as there are only 4 of them And sometimes the rotor arm could be dirty or burnt like mine was, so just needs sanding off maybe so that the rotor arm can spark up again.
