GTi drive shafts!
kyle18uk
464
Nottingham
hello all! ive done a search and not really found anything
im in need of both drive shafts for a mk2 ibiza 16v gti, anyone know what other shafts are the same?
I need them asap!
thanks, kyle
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
from memory it was 100mm diameter on the inner CV but sadly don't ask me on length or what golf ones fit as i only broke my inner one and gearbox casing
as long as it's 2.0 the 8v+16v shafts are the same as far as i rememeber and one one odd rare toledo one but i'll rummage and check for ya
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
for a whole shaft as long as it's for the 2.0L ye
there is a few Caddy/Corrado/Scirrocco/Polo variants that have the same part number fitted but most are so odd and rare it's scary
will be easier to stick to Ibiza/Cordoba for easy street
kyle18uk
464
Nottingham
So get them as a pair from either the 8v or 16v? There's a few 8v's being broken on eBay at the mo so will send some messages!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
just be sure they are 2litre that's all and yes the inner's are 100mm not 90mm
silly Q ? what gearbox you using in this project ?
kyle18uk
464
Nottingham
Thanks for that mate.
It's a golf mk2 gear box to keep it cable change from what I know, got a weighted shift rod to. Does that make a difference? (I'm learning as I go along!) Got 16v hubs and discs on it.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
knowing what you are up to i had to wonder what box used and what size inner drive plates you had to match with the 100mm shafts ?
