GT3071R ibiza build thread
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
its not legal in anyway tho is it? running a screamer pipe the length of the car that is? or any length for that matter! food for future thought!
bill im sure ive told you 3 times before!? yea 38mm
thanks matt! i am really pleased but rs fab took my cloud away abit buy draining my funds! i feel sorry for my customers this week lol
thanks for comments people.....it keeps me going!
HoocH
TTS Roadsport
VAG specialists
Apr 24, 2006
229
Bedford
www.ttsroadsport.com
Looking good mate.
Did Chris make the harness bar for ya? Little tip, use a bit of velcro where the harnesses are attached round the bar. Stops them moving about and rubbing on the turrets. Esp when you dont have a passenger. Where are the harness pads???
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Dont talk about legal being an issue, Mr decat :LMAO:
go on.. you know you want to...
:D
h17och
Sep 1, 2005
3,504
Dunstabubble
chris didnt make it na, got a local lad to!
no harness pads yet i want to see yours again 1st :)
i bought a 38mm-44mm vband adaptor so i can run ur mani bill but then went with rs fab.
i think a decat is a little more discreet than i screamer pipe. but i may make a blanking plate for the dp and make a scremer pipe for the odd occasion lol
h17och
Sep 1, 2005
3,504
Dunstabubble
this is the rose jointed turbo support bracket they made
and this is how ive ran my brake pipes (also you can see my ecu cover :) )
h17och
Sep 1, 2005
3,504
Dunstabubble
proberly not bill but i thought they would be better away from the heat. and once they were removed i managed to cut down the abs unit bracket loads which created a nice space for the wastegate as i wanted it where it could be seen easily :):)
HoocH
Nov 2, 2004
9,335
South Wales
Hooch, something off topic a little, but you might want to check the cam chain clearance on that that smooth cover, mine has made a nice groove in my cover. Only found out when i took it off.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
HoocH
ahh yea the ABs pump.. I forget about that as mine been binned for years.
you ceramic coating anything or wrapping it etc?
the brake lines went behind a shield as std tho did'nt they.
h17och
Sep 1, 2005
3,504
Dunstabubble
thanks phil, what would you reccomend?
bill im ceramic coating everthing end of summer once i know all is good!
they used to have a crappy little heat sheild over them but not great
thanks cupra200bhp, not long now
mani was flowed tonight......
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
my crappy little Oe heatshield seemed to work during racing. ;)
everything else within sight of the manifold and DP tho needed additional shielding as it all melts. muchos hot
Nov 2, 2004
9,335
South Wales
Difficult to say, you could double up on the gasket for the rocker and make sure its torqued down well to stop leaks. But i might have a feel i got a pattern and not OEM gasket on there as the half moon leaks oil along with the back part so i'll replace than with an OEM and let you know how i get on.
Ianb
332
Ceramic coating of manifolds normally start at £200+ +vat from Camcoat.
Looks tight in there re heat dispersal.
Bill s right re heat shielding. Even on my Golf there's quite a bit of room all things considered but boy it don't have get hot behind there.
I've put additional wrap around my I/C pipe work but have taken off the heat wrap on the manifold. I'd wrap what you can in foil wrap.
I've been considering some extra ducting to get more air in behind....God only knows how much heat Bill's car produces on an even more confined space.
h17och
Sep 1, 2005
3,504
Dunstabubble
ive found somewhere better than camcoat. but £40 per foot on 40mm mani pipes.
but if it ever comes off its free to re-coat it!
