Right I need peoples help here. I recently got my motor back after having a GT2x, 3” ATP inlet, S3 injectors (with 4 bar FPR) and 3” MAF fitted.
I got it all mapped with wideband lambda and its holding good a/f ratios right through to 7,000, with very little/no timing pull. However it seems extremely laggy…. At first I thought it was just me getting used to it, so I did a log of requested vs actual boost and its rubbish (not meeting requested boost till 5,000 !!!). Once the thing is on boost it bloody flies all the way to 7,000 and is a lot quicker than the K03s used to be.
At the same time I logged air flow and it was pulling a pathetic 125g/s (my K03s used to pull around 185g/s IIRC)
Basically I bought a cheapo 3” MAF from a member on here which when I plugged it showed was knackered so I swapped the element from my original MAF (obviously 2.5”) and put it in the 3” housing. I also have the cheapo open air filter that came with the kit fitted. Do you think either of these may contribute to the problem ??
By the way for reference my other mods are A&M manifold, 2.5” miltek d/p and cat, Miltek full cat back, Forge FMIC, Forge DV007 and N249 bypass.
Now there are few running the same mods who see full boost by 3.5k, cupra_matt, robdon maybe you can confirm this ??
I’ve got a log but my work internet security won’t let me access photobucket, anyone be able to host it for me ??
