Solyarkin
We had the car at Santa pod for USC had the car put on the dyno we made 534bhp on 28psi and still on the base map but will have to get a bigger wastgate spring as 28 was as high as we can get
28psi ~ 1.9bar...?
my car now 500hp 600nm - 1.75bar
Just a bit of a update as I ain't been on here in some time just getting the car ready to enter two drag racing championships one is euro sports compact and the other is vwdrc just had a full weld in cage fitted by cage laser engineering big thanks to them for sorting that out for me
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Odd design of the second hoop.... that would normally 'not' mount in the same place and would be made of one piece (and be further back)
westallc
132
saw this today what power you at?
got a couple of vids of it when it did a 12.1 and 12.0 think you went 11.9 at one point ??
westallc
132
did look like it was struggling for traction off the line but it looks ace got a few vids and pics i will send them to you once there up loaded . what is in the corrado black one it was flipping mental
Ronin225
4,652
22
Worcester
Danny, are you going to be at any shows this year as i could really do with having a chat to you about the electronic hardware and software alteration you did for your 4 wheel drive conversion
grahams81
1,165
County Durham
I've read above that Dannys using the SQS manual haldex controller same as what im planning. It doesn't use any signals etc from the abs unit or ecu.
This is what i'm planning on running (exept with the handbrake cuttoff switch).... No wires just remove the standard haldex controller (fitted on diff) and bolt on SQS one.
Ronin225
4,652
22
Worcester
Thinking this maybe the way forward then
I will still trace the wiring through the loom on the OE system to see where it goes though
Its been some time sines i been on here but had a busy year so a bit of a update and a big thanks to all my sponsors without them i would never got in to the 10s best run this year was a 10.82 @ 133mph
INA engineering
TKC mag
Forge motorsport
caged laser engineering
silicon hoses.com
lucas oil
millers oils
sabelt
nimbus motorsport
vidette uk ltd
Genix
hoosier tires
http://www.dubshackracing.co.uk
http://www.facebook.com/pages/Dubshack-Racing/109959655766356
Ronin225
4,652
22
Worcester
Its changed quite a bit since you were last on here but looks much more purpose built
Do you change wheels and use it on the road or is it full blown race car now?
