just got the gmax suspension installed.. dropped by 30mm all around.
but i just have some problems which hopefully u can answer!
when take corners at speed, it sounds as if the wheels are rubbin the arches, at the back of the car. but when ig et out, i cant see and wear on the tyres, or have rubber on the arches. i also guessimate that the wheels are too far in the arches to touch them, as i have no spacers on the rear.
another problem is that when i go over the smallest speed bump or pot hole, the rear makes alot of sound, as if the suspension isn't oiled enough. i cant describe the sound, apart from being loud!
but apart fromt this, the suspension is actually really good, the car feels to be going alot faster, where i was doing 90, i'm now doing 95, and i can do roundabouts at 50 instead of 40.. so i'm not gonna complain.
just wondering if i should oil/grease the suspension, or will it wreck it, and should i be experiencing problems with the wheels touching the arches
