Girling 280mm front caliper Brake slider pins
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
It seems the original part number may be obsolete but Sierra is worth a try to match up and recently found the Ssangyong Musso runs a similar style slider too
If anyone has an original set lying about Front/Rear i would be interested to know the exact sizes as the rears are shorter but for that i need to look for a lot of late models as the girling rears were used on literally tonnes of non VAG Cars
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
10 mins brain storming among the many models i have seen with the right make/style and i've found 1 possible alternative
Peugeot 405 Rear
Citroen ZX ?
Can't confirm as yet as to exact dimensions length/diameter etc but will do my best to find the alternative for both front and rear and will update as found
If anyone has access to measure Peugeot part number 443911 it would be appreciated
thanks
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Sierra Kit looks worth a check as suspected - Link
Ssangyong Musso is a very similar size/diameter to the Ford so also worth a measure as well - Link
sheriiff
83
northallerton
That site is quite handy, im gunna get a couple of them service packs for my brakes, my rubber kaiters on the slide pins av split, they would fit the rear aswell i hope.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
I'm holding out on buying seals till I ask a dealer. The gaiter seals should be the same front and back I think.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
oooh good find and a better chance than the ones above as they will need measuring to be safe
by the way the Ford number is still current and stock available but remove the F before quoting - i will edit to suit
to add to the list above as most were rears and i believe shorter - Clio Sport fronts use similar girling 280mm size calipers so another to check out too
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Literally hundreds of different cars have the exact same pins if you search BCF1301 in the website. http://www.brakepartssuperstore.org.uk/contents/en-uk/d10782.html
