Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
I would check the linkage first. Get a friend to go through the gears while you watch the linkage in the engine bay, you might spot something wrong/where to adjust.
but if it's rod change, then most likely need the linkages looked at, mine used to do it, then i lost all the gears , had to drive home in 3rd, involving pulling off at lights
hi, i find that sometimes my gear stick loses its spring and therefore find it hard to get into gear. i only have this problem once the car has got hot, and the gear stick comes really stiff hence losing that spring feel. any idea's what causing this? is it the end of my gear box?
