gear linkage?
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
here are mine no clip, sorry about the pic its dark
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
That guide says to undo that nut with a 15mm socket and pull the shifter up. Probably the same on yours, you tried that?
Deleted member 12147
Just undo the nut circled, then to the right of your pic there is a black plastic adjuster (with a spring on) pull this upwards or as the guide says pull the springloaded black adjuster towards you and remove this way. It has a ball type joint and should just pop off. You will then need to wiggle the linkage off. I think the golfs also have the ball joint type linkage.
