gear knob help
nev
Mar 27, 2007
618
Southampton
did a search but couldn't find the guide to do it :rolleyes:
is there anyone that can help me, looking to change my mk3 gear knob for an aftermarket one but not a seat. Looked at the fitting and didn't have a clue of how that would work????
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
yep very easy mate.
basically:
1) pull up the booting around the gear stick, (becarefull nto to break the plastic tabs!!
2) look under the plastic cover and on the inside you will see a rubber boot held in place via these plastic tabs.
3) pull the top cover boot up (leaving the rubber boot down)
4) you should then see a copper ring around the bottom of the gear stick, pull this off with a pair of plyers, (you probably will need a new ring so order one in)
5) once that is removed, slowly twist and pull the gear stick off :)
oh btw i have a red momo gear knob if you want it for 15 delivered
oh, aftermarket gearknobs should either fit on like standard gear knob or should have some grub screws that you can screw in to the gear stick to hold it still.
hope that helps
Adam :)
nev
Mar 27, 2007
618
Southampton
quality, cheers for that mate. do i have to order the part through the dealer?
and cheers for the offer but red wasnt what i'm after:)
