Fuel Injector Rail - PLZ HELP ME
asimtahraf
12
Hi
i’ve been told by my garage that i need a fuel injector rail and a fuel injector
best to find it pre-used without it being expensive
i don’t know much about cars and i don’t know where to find it for a good price
how do i know it’s the correct part? and can i use a 1.4 ibiza fuel injector rail or does it HAVE to be Cupra specific?
PLZ HELP
SEAT Rule
188
62
Hello there,
I think these are the part numbers for the items you're possibly after, for SEAT Ibiza 1.4 Cupra DSG with engine code CAVE.
Fuel injector rail
Part number 03C 133 202AQ
Fuel injector
Part number 03C 906 036M
(Up to year 2012)
Fuel injector
Part number 03C 906 036N
(After year 2012)
Injector seal ring set
Part number 03C 198 149
I'd contact your local SEAT Main Dealership for prices and availability, plus to confirm if the above is correct.
Also you could check on Ebay.
Hope this helps
Si
asimtahraf
12
Hi,
I brought the injectors and seals (1.4 correct model) and gave them to my garage. He’s took the old ones out and these don’t fit...
Even though my car is a 1.4 it takes 2.0 litre injectors???
He’s saying it’s possibly a remap but i’m not sure.
SEAT Rule
188
62
Hi,
Hello there,
right ok I've been doing a bit of digging around online, yes it is a possibility various parts/items on your CAVE engine have been upgraded, some owners fit upgraded fuel injectors to match the raised fuel pressure from a remap, including high power fuel pump and even high lift cam shafts ?
I think your 1.4 Ibiza has two fuel pumps,
first one is a low-pressure pump inside the fuel tank, and the second is a camshaft-driven high-pressure injection fuel pump.
Looks like the standard 1.4 CAVE engine fuel injectors have 6 spray nozzle holes in their stem tips.
If your mechanic is adamant that they are upgraded 2.0 injectors, then they should have a part number or serial number on them, this way you'll be able to trace/pin point the one's that were in there already, it might even have a different upgraded injector rail to match injector fitment ??
There's a 2.0 TSI/TFSI but it's fitted in the Leon and Golf with eng code CCZB
From late 2006 to 2012/13
Injector part number 06H 906 036G
These have the longer injector stem nozzle with the same 6 spray hole stem tip arrangement, and connection plug/socket is set at an angle of 45°, but the 1.4 CAVE engine has the connection plug/socket set parallel 90° to injector body.
From 2012/13 onwards (eng codes CJXA / CJXE)
Part numbers below are fitted to MK3 2.0 Leon (Bosch part number 0261500076)
06K 906 036
06L 906 036J
06L 906 036L
You'll need to get your mechanic to check the part number/serial number if any, from your old injectors that he's just removed, and see if they match any of the above numbers I've listed, also I think you possibly can get injector nozzle adaptors for these direct injectors. Your mechanic may need to check measure the so called 2.0 injectors he's removed against the standard 1.4 CAVE injectors you purchased.
Other then that it's to look through your service history and see who did the remap,
or contact the previous owner if you bought the car from a private seller ??
Also I've found this thread from a few years ago that has great information, on the known faults/problems with the 1.4 twin chargers engine, plus info on the updated replacement part/s
Link below:
https://forums.seatcupra.net/index....ate-guide-1-4tsi-fundamental-problems.407682/
Also link below for info on what items are mainly upgraded on your 1.4 CAVE engine:
https://www.torquecars.com/volkswagen/1-4-tsi-tfsi-twincharge-tuning.php
Hope this helps
Si
Reactions: asimtahraf
asimtahraf
12
You are perfect help thank you.
We did this, he found the same injectors at a SEAT specialist garage and he replaced them.
Job is done. I know the vehicle isn’t remapped but i know several things under the bonnet have been upgraded.
Now i have 4x 1.4litre fuel injectors and nothing to do with them lol. I got them breaking so not sure if he will take them back either.
THANK YOU SO MUCH!
SEAT Rule
188
62
THANK YOU SO MUCH!
No worries good to hear you got it sorted.
Si
