Fuel Economy?!?!
alb
63
Sheffield
Right, afer handing over a nice crisp £10 to the woman at the petrol station yesterday, i managed the grand total of 39 Miles in my 1.4 untill the petrol light was lighting up my dash again, which is obviously not good! :wtf:
After readind wilz thread the other day, i understand that the Lambda sensor may be to blame? is there anyway i could check this before spending £50 on a new sensor? Also, what else could be the problem?
This really needs sorting now, as its costing me a fortune!!
Also, would the car running this rich cause any other more serious problems at all?
cheers,
Dan
kiearn
156
Norwich
Get it put on a computer to check for fault codes. Ring a few local garages and ask how much it would be and you may get it cheapish. The bigger garages (Seat also) will want you to book it in.
Jun 17, 2007
1,032
Aberdeenshire
Go to a garage mate local one for cost and get them to put it on the fuel immission tester they should be able to tell with what readings its got. if its through the roof like mines was its either the lamba sensor or your ecu a think thats the other thing as it was to high to be the cat
alb
63
Sheffield
thanks for the reply's, il try to take it up to garage asap!
If it is running to rich, is this likely to cause any major long term problems? A mate of mine had a pug 106 which the head gasket went on, and the garage that fixed it told him it was because it was over fuelling! Could really do without the head going on mine...anyone know if that could happen on a mk2??
thanks,
Dan
Sep 20, 2006
756
Birmingham
cheers,
Dan
Ill hopefully get my car checked this week to see if the lambda sensor has gone/not working properly. Like i mentioned in the other thread im getting crap fuel econompy at the moment as well.
Will keep you guys informed.
fuey
i wana go faster
Jan 12, 2004
437
north west
uk.geocities.com
This is what i had on mine... so i changed the fuel pump relay.... (was only 11 notes...=cheaper..)
but it's my lambda thats gone.
(disconnected it, and the car idled fine = better than when it was connected)
Address 01 -------------------------------------------------------
Controller: 6K0 906 025 D
Component: SIMOS 4S 3505
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
00537 - Lambda (Oxygen Sensor) Regulation
19-10 - Lower Limit - Intermittent
18-10 - Upper Limit - Intermittent
Readiness: N/A
The stealership gave me a print off from their machine (50-51)
