Front Splitter - What screws do i need?
schnipps
237
Ok i have seen the guide on how to fit it but you need 8 self tapping screws, but there is no part number so i assume you get these from B&Q or something. What size self tappers do i need?
satilaboy
375
b&Q or homebase etc.
I can't remember the exact length i used but they were not that long. just enough to fit through the splitter and underside of bumper with a bit to spare.
I used 10 screws (2 additional at the mid section) as i felt the mid section may flap at speed as it felt comparatively loose compared to the sides.
have a look at the screws in homebase, you'll be able to gauge which ones suit visually
Lee M
Hi mate,
You will probably find that 12 - 15mm self tapers will do the job. 15mm would be better if you can get them.........B&Q, Homebase or Wickes are a good bet.
Lee
andycupra
status subject to change
fatter shorter screws with wide head and course thread are best as the bumper plastic isnt that thick so you want to get as much purchase as possible.
some people have not drilled a pilot hole, some have.
best tip is a spare pair of hands as trying to do this yourself is not easy.
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
I taped the splitter to the front bumper, then got under & put it on. Think the screws i used were about 3/4 of an inch long !
Ibiza Cupra
When you get the splitter from seat just ask for sum self tappers.
The bloke at my local dealler chucked in about 30!!!!
I used 20!!!! 8 seems a bit stingy but then mine is solid!!!
jaybeee
[e]
Feb 24, 2006
202
Belfast
www.metalrhino.com
^^ Hope it never gets ripped off! That would really make a mess of the bumper what with there being 20 screws in there.
I just used pabs's guide. Used an awl to create little holes first, to help me know exactly where to put the screws when you're on you back trying to screw the fncker in (ooo, that sounds dirrrty). I used masking tape as well to hold it place as I screwed it in.
Got some ~25mm fattish self-tappers from Homebase.
Basically as the rest of the chaps above have said really. Tis a great little cheap mod as I really think it helps set off the front of the LC. Esp in black ;)
It's prolly bout time I did some proper mods eh! lol
schnipps
237
Got it on, wasnt that bad to fit, put 12 screws in, but i cut too much off the 2 middle bits so thay are are about 1.5 cm short now...doh
