Front nearside wheel bearing
cazzbazz
Hi, can someone point me in the right direction on how to change the front wheel bearing on my Alhambra.
Ive got a rough idea, it would just be nice to see or read how its done as ive not got a Haynes manual, will i need a puller?
Thanks for any advice.
90landrover
308
Rhondda,S Wales
Hi
You should not require a puller to take the hub of but will require something to remove the old and press in the new bearings.
If you get a haynes manual for the ford galaxy all is explained in there.
cazzbazz
so when i remove the bolt from the centre of the hub, will i be able to knock it off with a hammer?
