front lower strut brace?
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
anyone got one? how do you fit em? never seen em fitted before, does it make a noticeable difference?
kyle18uk
464
Nottingham
Ive got one, very easy to fit, just remove two bolts and then bolt the strut on with the same bolts.
Couldnt say how good they are as my car hasnt moved an inch since fitting, can try get some pics if you want?
kyle18uk
464
Nottingham
not mine but best pic i could find of how/where it fits.
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
nice just done mine :) it grips better out of corners well worth while! 20 quid well spent!
BubbleBoy
Goes Like Schnell
Feb 17, 2010
104
Sweden
Were did you guys find the lower strut brace? :confused:
I want one myself! :)
Can't find any on ebay? :(
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
I don't like the polybushes on the rear of these style wishbones. The poly is just to hard and doesn't flex like the original is designed too. Whoever designed them obvioussly wasn't thinking about how the wishbone was designed to move. It either needs a spherical bearing or as you say an lcr style full rubber mount.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i wonder what difference tubular arms would make ?
bit of weight saved i guess (2kg ?) + be able to design in some adjusters i guess
Ronin225
4,652
22
Worcester
You can get race rear wishbone bushes which in essence are rose joints, but very solid ride
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
I doub't you'd save much in weight with tubular arms. But note these pressed steel ones are very stiff in the direction that forces are applied. Main thing would be for adjustability, but until your running a serious track car and changing the setup and doing lots of testing you won't gain alot by having that adjustability.
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
I'd imagine with a polybush front mount and rear spherical bearing (rose joint per se), you would not have an overly harsh ride. Harshness of ride should mainly be absorbed by the shocks and springs. Wishbones just take lateral front to back loads from braking and accelerating.
Ronin225
4,652
22
Worcester
Did look into doing race ones, but feedback from people who had said it was too hard and unforgiving and swapped back to poly
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
must admit rings a bell someone here had a mk3 with fully rose jointed ones on road ?? and obvious results of hating it
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Ibizaalex had them on his mk3. I didn't think he hated them though.
At the end of the day genuine rubber bushes last over 100k miles usually and give a good compromise. Thats what I'll be buying if I ever need them.
Consumer market will buy anything as shown by rear poly mounts.
crossedmike
hmm im tempted ? i have front top and rear do i go for bottom ?
