jamiebennett81
over the last couple of days vibration from the front wheels is becoming progressively worse
The ABS light came on the other day and the feedback from the front wheels was pretty bad (instant vibration)....as if trying to drive and it was gently braking at the same time
when the light came on, I pulled over, turned off the engine and back on again to see if the light would reappear and it didnt....appeared to clear itself
I have just run vagcom on it and there are no error codes
there was always a little bit of vibration due to the track density engine mounts, but this feels a lot worse
I have checked the KW's and they are not leaking. The ride just seems to be quite bumpy...as if I have got a flat tyre. I checked the tyre pressures the other night and they were all fine
it seems to be getting worse by the day. It is going into AMD on Tuesday luckily to get a number of issues sorted before it goes to Bills
what could be the possible cause of this? The car has done 86000 miles and is on a 2001 plate i.e. typical causes for excessive feedback or vibration through the steering wheel and a very clunky like feeling to it when I drive her??
could it be the bushes need replacing or something?
OR the only other theory is if the ABS is not working properly i.e a faulty sensor, despite their being no error codes, does this interfere at all when driving?
