Front end knock
cliveyp
LCR Abuser
Jan 11, 2006
219
Worcester
This week i've developed a knock/clunk from the front nearside wheel area. I've heard it 3 or 4 times, normally when i hit the brakes suddenly in reverse. Whats it likely to be? Drop link or something??? Can't really feel it through the wheel much but there is a definate noise and its slowly getting louder.
andycupra
status subject to change
some pads move which may produce a click when changing direction, ie forward to reveres..
changed the pads lately?
if it didnt used to do this then probably not that.
otherwise it could be a number of things, wear in one of the joints.
wheel bearing.
drive shaft
loose wheel bolts.
track rod...
cliveyp
LCR Abuser
Jan 11, 2006
219
Worcester
Cheers for the list mate, i'm pretty sure it won't be brake pads as i changed them a few months ago, and this has only really developed in the last week or so. It's when i initially hit the brakes so i was thinking of a joint, although i will check the wheel bolts just in case........
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
I think i hav the same noise wen i drive forwards in first gear slowly n brake i get a clunk then slowly move backwards n brake it clunks again i throught it was a anti roll back/drop link gone had it in at seat and they checked it over and said sum bolts had come loose on the anti roll bar mounts to the subframe, had them changed and all fine said seat. but not the case i still hav the noise n had it a while now but it aint changed.any 1else with ideas thx john
rizzler
I had a knock like that. I tightened the antiroll bar bush clamp and it sorted it
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
This is one of those problems that really needs time on a ramp to sort. That way you can check all linkages, bushes and clamps are tight and correctly fitted.
Muds
My first post, just found this site today. I had a similar knocking sound on my Cupra develop yesterday. Had a dig around tonight and found the top part of the front offside suspension spring (about 3" long) wedged inside the rest of the spring, that explained my front end knock.
didsi
I Want an LCR!
Aug 25, 2006
123
this sounds very similar to the problem i have, a knocking when i brake, i had the pads channged last month and a friend told me its the pad moving when i brake. Apparently its easy to fix but im getting mine looked at sometime this week so ill let you know.
Dennis
Polisher
May 11, 2005
297
Mintex do some sticky pads to go on the back of the brake pads that the pistons bite into, you can also ut these up and you can stick it to where sides of the pads sit in the caliper.
Lotus sell the pad things to go on the ap callipers on the elise but they ar enot cheap so I now go for the mintex sticky pad things.
NB make sure the areas where you are looking to stick these is clean and dry
