Front brake disc Torque Wrench settings.
NickT
429
LB, Beds
...Interestingly, reading my Golf IV manual (the nearest Haynes reference for the Leon/Toledo) I find it makes no mention of the need to replace the front mounting bolts, only the rears. So perhaps the front attachment is designed to stay done up without needing loctite after all.
Good point, I've got the Haynes as well but when I came to sort my fronts out I was informed by a local spares place that the mounting bolts were SEAT parts only as they came pre-treated with loctite, maybe some confusion between the front and rear application as you mentioned...:shrug:
Brownster
Pure Brownmonsterage
Mar 4, 2006
59
sheffield
That could have been dangerous.. :blink:
With the disc screw, I just drill through and then run an M6 tap through the hole in the hub.
How long is that tap? I wasnt expecting the screw to be that long? Is it easyto get out when changing your brakes again?
Ste
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
DPJ wrote
Strictly speaking, It's not the 'loctite' factor. Caliper mounting bolts are usually one-use stretch bolts that shouldn't be re-used. Correctly torqued bolts shouldn't need threadlock.
Elsawin describes them as "self-locking", a description that makes more sense if applied to a threadlock coating rather than a bolt which is stretched beyond its elastic limit by assembly.
All torque settings are about applying a pre-determined amount of stretch to the assembly, bolt or stud. Stretch bolts appear to be used in automated car assembly to give a wider degree of latitude to the safe fastening range - x number of turns rather than a precise torque.
I've been told by VW technicians that the bolts on the Girling calipers on my old Golfs were attached with pre-coated bolts and that it was as effective to use the old bolts with loctite when doing DIY pad replacement. I believe it's the same for the rear caliper bolts on the Leon/Toledo. The front caliper attachment bolts are not specified for replacement if disturbed, according to ElsaWin.
NickT
429
LB, Beds
Ste
The actual retaining screw is 15mm long as I mentioned earlier in post #9, the tap doesn't replace the screw, it just re-cuts the thread in the hub which almost inevitably gets spoiled trying to remove the old retaining screw.
Brownster
Mar 4, 2006
59
sheffield
Yesterday I spoke to the local Seat dealer and he said they wouldn't usually replace the bolts unless faulty, especially as they are quite pricey to replace, and he just advised me to Loctite them.
Ste
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
that's because the dealer is wrong.... they're not that dear at all, and you don't want your brakes coming loose
dealers are NOT the fountain of all knowledge by a long shot
NickT
429
LB, Beds
I always buy & fit new caliper mounting bolts from the dealer. The ones I've had certainly weren't ever coated...
Mine didn't have any threadlock residue on when I removed them which I would expect to see if it was used.
However Vagcat.com refers to the bolts as "N 90708502 Self-locking bolt M12X1,5X35" which suggests they are stretch bolts or use an alternative means of mechanical thread locking (although the only alternatives I know of are thread locking inserts, which I doubt would be used in this instance, or tie-wiring, can definately rule this one out).
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
They're stretch bolts Nick. I've bought and fitted several sets.
NickT
429
LB, Beds
The only thing that gets me is, having used the MkIV Golf/Bora Haynes manual for reference when doing my fronts, it doesn't mention anything about replacing these bolts so I refitted the originals, at risk it now seems, arse.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
ElsaWin's Seat data doesn't say anything about replacing the front mounting bolts either, only the rear ones.
Brownster
Mar 4, 2006
59
sheffield
Right all sorted now thanks for your advice.
Once last question - when i wound my calipers back in I didnt take the cap off the master cylinder, once done i noticed that there was a little pool of fluid on the floor. Looking at the cylinder head it looks to have leaked from there! however if it didnt how soon could i tell when pressing the brakes - i dont wanna be driving along the road and realise that there is a leak in the system that i have caused, and have no brakes!!!
what are the chances of it bursting a pipe in the system? am i being paranoid!?
Ste
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Ste
Your master cylinder won't have been filled to the brim, so you'll mainly have been compressing the air in it when you wound back the pistons. You're unlike ly to have burst anything, certainly not a pipe. Clear up the mess and don't do it again! :)
