Had a bit of a play yesterday, gave the panel filter a clean, Plus had the standard cold air feed that goes from behind the head light to the bottom of the air box removed,
I cant believe how restictive this looks as standard, i possibly think it a combination of cold air and sound deadening to effect,
So ive had a bit of a play, using an external air temp sensor fitted to the inside of the bottom of the airbox, once with the cold air feed in situ , one with out, even with it removed the cooled air is naturally fed from behind the light because of the existing front part of the pipe still being there,
feed in situ : 19.3 c
feed removed 19.4-5 c
0.1-2 of a degree will have no effect on a Intercooled turbo'd lump In my opinion, And since the diameter of the feed pipe is down at least 1" over the entrance to the air box i personally think it'll be far more efficient
the biggest benefit ive found up to now was the immediate grunt midrange especially 5-6th on motorways, it pulls harder everytime, something ive always thought to 180 LC lacked as standard.
I replaced the cold feed pipe to see if it was just the placebo effect, but im near on 99% sure it wasnt,
Plus you get a nice induction note too, its not droning either,
