Like most of the people, i was quite disappointment with the Beats system that came with the Formentor, and being a bit of a car audio "enthusiast" I could not let it go and started the upgrades.
First upgrade I did was opening the port on the Subwoofer, and the topic was posted here.
Next step are the doors. There are videos online, which show how to remove the door cards..
Since i want to do it propperly, i ordered 3 door sets. These are from a Finnish retailer, but can be found pretty much anywhere. I chose this material since it was affordable, and covered all aspects of door insulation.
CTK Premium 1.8 - 20 sheets used for front and rear doors
CTK Elastic 10 - 9 sheets used for front and rear doors
CTK WaveFix 15 - 8 sheets used for front and rear doors
Front doors:
First layer was the CTK Premium 1.8, which I applied to the inside of the door. I managed to cover about 90% of the surface, leaving my hands scratched quite a bit . After that CTK Elactic 10 was applied to the Premium 1.8 layer. The same was applied to the plastic covers for service asses within the door. After that, additional patches of Premium 18 were applied to the "outside" of the door, to reduce vibrations. I did not want to go super crazy here, as I wanted to keep the servicibility of the door components (not shut everything close, and avoid too much weight)
Front door cards:
Here, the first layer was the Premium 1.8, to reduce vibrations, and add some weight to the cards. I applied it where i could since the door card has a tricky pattern. After that, a layer of WaveFix 15 was applied, which serves as a good sound insulation, and also "creek" insulation since it compresses everything together.
I did not show it on the pictures, but I added a fabric tape to the door card clips in order to reduce any possible vibrations.
Rear doors and door cards:
Once all of this was done, there was a significant difference in road noise, and the bass and overall sound reproduction as well.
If you have the time and will, this is the first upgrade i would recoomend, before replacing the speakers or adding an amplifier.
Next steps will be the booth insulation, and front speaker replacement - which is in progress and I will write about later on.
I also wanted to add a comment about the Beats system overall loudness. It is quiet, but tehre are ways around it.
It does seem that the system is picky, and it depends which source is being used. FM radio is quite OK, while CarPlay is quiet. So far, the loudest option I found on forums was through Bluetooth, but than the seetings need to be changed. Once the phone is connected to bluetooth, go to sound / loudness settings, bluetooth audio, and switch it from Quiet to Loud.
This makes a massive difference, and the system sounds waay better, and it actually is loud. (I do not know if this was mentioned anywhere here, but I stumbled upon this on a german forum)
Front doors:
Front door cards:
